=> Carrier Aggregation (CA) is a feature of LTE-Advanced that allows mobile operators & devices to combine two or more LTE carriers into a single data change. It leads to an increase in the capacity of the network and the data rates by exploiting fragmented spectrum allocations. This technology can apply to either the FDD or TDD variants of LTE. However, with a maximum of five component carriers. Each with a bandwidth of up to 20 MHz, resulting in a total transmission bandwidth of up to 100 MHz.
=> In Carrier Aggregation, multiple frequency bands are assigning to one device. They are component carriers and there are six specific frequencies. Those are: 1.4 MHz, 3 MHz, 5 MHz, 10 MHz, 15 MHz, and 20 MHz. One can combine at most 5 of these component carriers to transmit aggregated bandwidth of up to 100 MHz. If you aggregate two component carriers then it will be 2CA. Whereas, if there are three or four carriers – then it is 3CA or 4CA respectively. The more the component carriers, the better will be the data speed.However, the most common one is wireless communication. When two or more component carriers belong to the same frequency band then they come together. This arrangement is intra-band contiguous carrier aggregation. Secondly, when the component carriers are from the same frequency band. However, they are separating by a spectrum gap then it’s intra-band non-contiguous carrier aggregation. Lastly, when the component carriers belong to different frequency bands then they are placed in separate frequency blocks. It’s called inter-band carrier aggregation.
=> It enables faster speeds, via multiplies the number of LTE connections between the phone and the cell network.
So instead of having just one LTE connection between the network and your phone, an LTE modem that supports carrier aggregation when paired with a compatible network can actually bond together multiple, separate LTE connections and treat them as though they’re one. It can double or even triple Internet speeds.
=> Jio: Band 3,5 & 40– Jio enabled Carrier aggregation in their All Bandwidths,
Airtel: 1,3,5,8,40– Airtel Enabled Carrier Aggregation in Band 3, 40 only,
Vodafone Idea: 1,3,8,40,41– Vodafone Idea enabled carrier aggregation in their 20mhz network.
Please sign in
Login and share
