[Unboxing] iQOO Neo 7 Pro Fearless Flame | The Monster Device🔥🔥🔥
Aojesh Moderator
2023-07-25 20:23
Hey Questers!
I'm presenting my favourite thread right here. The brand-new iQOO Neo 7 Pro is unboxed! The genuine Flagship Killer.
From the community's inception, this thread has been eagerly anticipated, and I can't wait to share it with you all. This Orange Beast is the best smartphone there is.
Let's get started.
Retail Box
Here is the iQOO Neo 7 Pro Fearless Flame retail box. The branding "Neo 7" is located in the top left corner, but where is Pro? Later, we'll discover that :P
Moreover, the lovely iQOO Logo is embossed in the bottom corner in the colour yellow.
Side of the Box
The Pro is now concealed at the box's sidewalls. Also, I assume that nobody has yet equaled the QOOLness of the iQOO Retail Packaging. It looks adorable because of the combination of the box's black colour and the yellow division!
Top side of the Box
Bottom Side of the Box
Both the top and bottom side of the boxes has the iQOO caution seal.
The Device
The device, which was tightly wrapped in plastic, is shown here.
TPU Case
The device and LID are then removed.
The smartphone will be protected from scratches by a very high quality transparent back cover that we receive.
120W Power Adapter
For charging the device, we get a 120W Flashcharge enabled power adapter. Which can charge the device from 0-50% in just 8 minutes!
USB Type C to C Cable
Following with the adapter, we get the high quality 6A Type C-to-Type C cable which will help the power brick to transfer the charge to the iQOO Neo 7 Pro.
Sim Ejector Pin
Last box content is we get a Sim Ejector Pin to open the Gasket Protected sim tray
Now, we are done with all the box contents of the device.
Let us have a look at the iQOO Neo 7 Pro
Display and Selfie Camera
Display
At the front portion of the device, we get a large 6.78" FHD+ 120Hz Super AMOLED 10-bit Display. It has a resolution of 2400x1080, and peak brightness of 1300 Nits.
Out of the box it has HDR10+ certification and Supports HDR in Netflix too.
Diving more deep into the display, it has Delta E≈0.32 and JNCD ≈ 0.28 rating.
Selfie Camera
It has a 16MP f/2.5 aperture selfie camera which supports video recording in 1080p 30 Fps
Rear Camera Setup
In the rear camera setup, the device sports 50MP GN5 OIS Sensor with aperture of f/1.88. It supports stablized video recording upto 4K 60Fps and various other exciting modes.
The Wide angle camera is of 8MP with f/2.2 aperture. You cannot record video with the wide angle camera.
Lastly, there is a 2MP macro camera sensor with f/2.4 aperture.
Top Side
At the top side of the frame, the device has an Built-in IR Blaster along with a noise cancellation secondary microphone.
Bottom Side
At the bottom side of the device, You will find the Main Speaker grillType C port which supports 120W Flashcharging along with audio output support.
Also, there is a Primary microphone, and a Gasket protected Sim Tray.
Right Side
At the right side, it comprises of Volume rockers, and Power on/off button.
Where as the left side is clean for better handling.
Back Panel
The device's Back Panel is its key selling point. The back of the Fearless Flame version is made of vegan leather, which is supple and feels incredibly high-end in the hand. If used without a case, it also maintains a very fine grip and does not attract fingerprints. And, iQOO Logo is embossed in the Glass.
The Box Contents
Lastly, In the Box you get :-
  • iQOO Neo 7 Pro
  • 120W Flashcharge Adapter
  • 6A Type C to C cable
  • Sim Ejector pin
  • Quick Start Guide
  • Safety Guide
  • Transparent Back Cover
Hope you liked the unboxing of the iQOO Neo 7 Pro. Please drop your suggestions in the comments section below.
More threads Coming Soon.
Related Threads:
ASMR Unboxing: https://community.iqoo.com/in/thread/24550
iQOO Neo Series
